How to hide a part in an assembly ?
SOLVED
Level 8
Hello all,
I would like to show and hide a part (in a model) when I click on a checkbox, how to do that ?
And I have the same question as before, but I was unanswered, how to play only a step in an illustrate animation ?
Thanks !
Re: How to hide a part in an assembly ?
Selected is an event and it is supposed to bind with services, besides that, you can also directly bind the value property (of checkbox) to modelItem and in the pop-up you can select invisible.
Yes it is possible to put a name on the part. Also, the drag-n-drop can be targeted to the name of the model-item in the left-panel, as shown below:
12 REPLIES 12
You can drag a Model-Item on the desired part and bind the checkbox click to the Model-item's invisible property.
Let me know if that works.
-Giri
When I am on the properties of the checkbox, and I drag the "Selected" value on the model-item, only services appears, how to bind to invisibility ?
Is that possible to put a name on the part instead a drag and drop, if the part is very small, it can be hard to find it.
Thank you very much ! And is that possible to do the opposite ? I mean, isolate a part.
Interesting!! I guess that should be possible. By isolate, do you mean moving the part out of the scope? If so, yes it  is possible and varies how you handle that part.
I mean, only show this specific part and hide all others parts.
Hej,
You will be able to do that show/hide by using a JS call.
For example: You can put the complete model invisible (without any coding) and just show the part, which has the model-item on it (e.g. by a button)...
Regarding the model-item placement:
- you can use the structure point of the part within sBom from Creo (e.g. Illustrate) and put the good value inside the occurence of the model-item.
After pressing enter it will then hookup with the good part from hierarchical point of view in the structure.
Hello, when I try to create a model item and modify manually the component occurrence to get an assembly, everything is okay. But when I scan the thingmark each model item I have created are moved and put at the wrong place. If I remove the model item in the view, everything goes back to the right place. I do nothing else, not even a action on it, I only modify the component occurrence.
Any ideas ?
In the studio :
Preview
Yes...
I've got the same issue... I already reported it :-).
You can manually resolve when you delete the coordinates inside the model-item (after it has moved to somewhere).
Don't set it to zero - just remove the values and press enter...
It seems to me like a bug
Martin
