How to hide a part in an assembly ?
SOLVED
Re: How to hide a part in an assembly ?
It is does not work, even if I delete the coordinates...
Well that helps on my side at least - to remove the coordinates after the part has moved...
however it is a bug and I hope it's solved soon.
The bug is still there. Any changes or a workaround happened from PTC?
