Import 3D Creo model to AR ThingWorx
SOLVED
Visitor
I made assebly in Creo Parametric 4.0 then input it to AR ThingWorx. It`s not full and i can get full assembly only if i change .asm to .stp but it not good enough for my project.creo.jpgthingworx.jpg
1 ACCEPTED SOLUTION
Re: Import 3D Creo model to AR ThingWorx
Have you tried saving the .asm as a pvz in Creo and importing it to Studio? When you change the .asm to .stp, do you have parts still missing?
Thank you. Now it works. If I open this Step file in Creo it is not looks like it was assembled, but in ThingWorx it does
