Include Java Script Dokuments
SOLVED
mn1
Aquamarine
Hi there,
is there a possibility to include .js files ?
I need to use the function round of math.js.
Thanks for help.
1 ACCEPTED SOLUTION
Re: Include Java Script Dokuments
I think the math module should be already available as part of node.js installation. When I check my Vuforia Studio installation I could find it  in folder:
C:\Users\<my_user_name>\Documents\VuforiaStudio\Projects\node_modules\three\src\math\Math.js
I think to access it you need to call some think like Math.round()
In generally it should be possible to use an external module. I think  C:\Users\<your_user_name>\Documents\VuforiaStudio\Projects\<your_projectName>\extensions  or extensions\js ... could be a good location where you can try to save the additional javaScript library file / I could remember that some time added libraries but could not find such example now. I think you must add also the path to runtimeExtensions.json file
But there is another simple way in JavaScript. So for example you can upload the javaScript file to you resource/Uploaded project directory and  load it by JavaScript e.g. :
//---------------START Loading the API-----------------------
$scope.loadMyScript = function() {
  $scope.asyncLoadScript("app/resources/Uploaded/myJavaScriptFile.js")
    .then(function() {
   console.log("myJavaScriptFile.js was loaded successfully" },
          function() {
    console.log("there something went wrong"");
//---------------END Loading the API-----------------------
    .then(function() {
          function() {
Hi @RolandRaytchev
If I copy your codelines i get the error:
ionic.bundle.min.js:150 TypeError: $scope.asyncLoadScript is not a function
In my folder I coudn´n find math.js.
Thanks for help.
I am sorry , I forgot , of course, to provide the function definition:
scope.asyncLoadScript = function (fname) {
  return new Promise((resolve, reject) => {
    if(fname) {
      var head = document.head || document.getElementsByTagName('head')[0],
          script = document.createElement('script');
      script.async = true;
      script.onload = resolve;
      script.onerror = reject;
      script.type = 'text/javascript';
      script.src=fname;
      head.appendChild(script);
