Hej everyone,
could someone put in an advice on how to get javascript to work with hololens?
even the simplest ones that I tried are failing. (opacity, visibility and so on)
Martin
In the Home.js:
$scope.app.visibility = function(){
$scope.view.wdg['modelItem-2']['visible'] = false;
the prefix "app" is important .
In the function you are calling it by:
app.visibility();
In the Home.js:
app.visibility();
For the interval function, especially with cancel interval using "scope.app" doesn't work.
In this line - $interval.cancel($scope.app.intervalPromise); HoloLens just discards it. Is there a limitation in using "cancel" method?
