I've noticed that the tracking drifts about a couple of inches. You can see it if you turn on "display tracking indicator" and walk around the Thingmark. Any chance this will improve? I'm testing models with two HoloLenses looking at the same ThingMark and there is a discrepancy on where the model is located in space.
Hi Brent,
Good question. There's multiple pieces to the answer of this question:
Hi Brent,
I never thought about the people in the room being used as tracking and can see how that would throw it off. I'll run some calibrations anyway and see if it gets better. One of our HoloLenses has always seemed to act a little off, even after resets and calibrations so it could also be that.
