Multiple Issues with Thingworx Studio
SOLVED
Level 1
I am facing few problems with Thingworx Studio
When I lauch the Thingworx Studio the welcome screen shows error as "Error occurred, check logs". I am not sure why this is happening.
When I open Thingworx Studio. I can still see my earlier created projects, but I can't load them and when I try to create new one, even that is not working. I can see window as shown bleow:
Please find the logs below:
[16:00:34] Studio Version 1.8 (0.1.12.1082)
[16:00:34] Status Message: Version 1.8 (0.1.12.1082)
[16:00:34] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[16:00:43] Starting node.exe
[16:00:43] debug: [twx-studio:logging] Debug logging enabled. DEBUG=twx-studio*,ar-extension*
[16:00:43] Mon, 16 Jan 2017 10:30:43 GMT twx-studio:logging DEBUG_FD=1 so the "debug" module will log to stdout instead of stderr
[16:00:43] info: [twx-studio:initializer] Node version: 6.9.1
[16:00:43] debug: [twx-studio:initializer] ThingWorxStudio dir:  C:\Users\sameergr\Documents\ThingWorxStudio
[16:00:43] debug: [twx-studio:initializer] Projects dir:  C:\Users\sameergr\Documents\ThingWorxStudio\Projects
[16:00:43] debug: [twx-studio:initializer] Extensions dir:  C:\Users\sameergr\Documents\ThingWorxStudio\Extensions
[16:00:43] debug: [twx-studio:initializer] ThingMarks dir:  C:\Users\sameergr\Documents\ThingWorxStudio\ThingMarks
[16:00:43] debug: [twx-studio:initializer] Move /VuforiaStudioEnterpriseExtensions
[16:00:43] (node:3212) DeprecationWarning: `DEBUG_FD` is deprecated. Override `debug.log` if you want to use a different log function (https://git.io/vMUyr)
[16:00:43] debug: [twx-studio:fileUtils] C:\Users\sameergr\Documents\VuforiaStudioEnterpriseExtensions does not need to be moved, it does not exist
[16:00:43] debug: [twx-studio:initializer] Move the projects dir
[16:00:43] debug: [twx-studio:fileUtils] C:\Users\sameergr\Documents\VuforiaStudioEnterpriseProjects does not need to be moved, it does not exist
[16:00:43] debug: [twx-studio:initializer] Initialize builderSettings
[16:00:43] debug: [twx-studio:index] Done with initialization
[16:00:44] debug: [twx-studio:index] Startup process.argv is ["C:\\Users\\sameergr\\AppData\\Local\\Apps\\2.0\\AGQK50HY.2AK\\ZWH4JWZ8.0LW\\thin..udio_cd45769e4d993f77_0000.0001_b83b4d91f9311a36\\node.exe","C:\\Users\\sameergr\\AppData\\Roaming\\ThingworxStudio\\studio-download.vuforia.io\\dist\\server\\index.js","C:\\Users\\sameergr\\Documents"]
[16:00:44] debug: [twx-studio:extension-manager] extensionName to require ves-ar-extension
[16:00:44] ar-extension version 1.8.290
[16:00:44] debug: [twx-studio:extension-manager] extensionName to require ves-basic-web-widgets-extension
[16:00:44] debug: [twx-studio:extension-manager] extensionName to require ves-sample-projects
[16:00:44] debug: [twx-studio:extension-manager] extensionName to require twx-data-provider
[16:00:44] debug: [twx-studioSmiley TonguerojectHelper] ["C:\\Users\\sameergr\\AppData\\Roaming\\ThingworxStudio\\studio-download.vuforia.io\\node_modules\\ves-ar-extension\\node_modules\\lodash\\index.js"]
[16:00:44] info: [twx-studio:index] *********** Preview listening on 127.0.0.1:4001
[16:00:44] info: [twx-studio:index] listening on 127.0.0.1:3000
[16:00:46] Proxying: http://localhost:3000
[16:00:46] Access URLs:
[16:00:46]  ----------------------------
[16:00:46]  Local: http://localhost:3001
[16:00:46] Watching files...
[16:00:46] Proxying: http://localhost:4001
[16:00:46]  Local: http://localhost:4000
[16:00:47] debug: [twx-studio:sockets] a user connected
[16:01:10] debug: [twx-studio:sockets] a user connected
[16:01:10]  [0mGET /%7B%7BprojectType.imgPath%7D%7D  [32m200  [0m5.223 ms - 2122 [0m
[16:01:10]  [0mGET /%7B%7Bview.imgPath%7D%7D  [32m200  [0m4.737 ms - 2122 [0m
[16:01:10]  [0mGET /%7B%7BviewType.imgPath%7D%7D  [32m200  [0m4.254 ms - 2122 [0m
[16:01:10]  [0mGET /images/%7B%7Bw.name%7D%7D.png  [32m200  [0m4.192 ms - 2122 [0m
[16:01:10] debug: [twx-studio:sockets] EMIT builderSettings
[16:01:10] debug: [twx-studio:sockets] EMIT updateProjects
[16:01:12] debug: [twx-studio:sockets] EMIT getProjectTypes
[16:01:16] debug: [twx-studioSmiley TonguerojectHelper] Copying /src/**/* to project, overwrite=false
[16:01:16] debug: [twx-studioSmiley TonguerojectHelper] Copying /**/* to project, skip /src/**/*,  overwrite=true
[16:01:16] debug: [twx-studioSmiley TonguerojectHelper] Symlink node_modules
[16:01:16] debug: [twx-studioSmiley TonguerojectHelper] Copy of project files complete
[16:01:16] debug: [twx-studioSmiley TonguerojectSettings] write project settings FacilityPlantNew
[16:01:16] debug: [twx-studio:utility:runProjectGulpTask] C:\Users\sameergr\AppData\Local\Apps\2.0\AGQK50HY.2AK\ZWH4JWZ8.0LW\thin..udio_cd45769e4d993f77_0000.0001_b83b4d91f9311a36\node.exe C:\Users\sameergr\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\gulp\bin\gulp.js init cwd=C:\Users\sameergr\Documents\ThingWorxStudio\Projects\FacilityPlantNew
[16:01:17] info: [twx-studio:utility:runProjectGulpTask] [16:01:17] Using gulpfile ~\Documents\ThingWorxStudio\Projects\FacilityPlantNew\gulpfile.js
[16:01:17] Starting 'init-src'...
[16:01:17] Finished 'init-src' after 1.47 ms
[16:01:17] Starting 'init'...
[16:01:17] Finished 'init' after 8.96 μs
[16:01:17]
[16:01:17] error: [twx-studio:utility:runProjectGulpTask] (node:7124) DeprecationWarning: `DEBUG_FD` is deprecated. Override `debug.log` if you want to use a different log function (https://git.io/vMUyr)
[16:01:17]
[16:01:17] debug: [twx-studioSmiley TonguerojectHelper] buildApp FacilityPlantNew
[16:01:17] debug: [twx-studioSmiley TonguerojectHelper] write settings
[16:01:17] debug: [twx-studioSmiley TonguerojectSettings] write project settings FacilityPlantNew
[16:01:17] debug: [twx-studioSmiley TonguerojectHelper] copy runtime extensions
[16:01:17] debug: [twx-studioSmiley TonguerojectHelper] packageThemeSet
[16:01:17] debug: [twx-studio:themeManager] generating studio-designtime-vars.scss
[16:01:17] debug: [twx-studio:themeManager] generating studio-runtime-vars.scss
[16:01:17] debug: [twx-studio:themeManager] processThemes
[16:01:17] debug: [twx-studio:themeManager] Making theme:  twx-light , includePaths:  C:\Users\sameergr\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\src\ar\src-scaffold\ionic\scss
[16:01:17] debug: [twx-studio:themeManager] Building twx-light-theme-designtime.css
[16:01:17] debug: [twx-studio:themeManager] Making theme:  twx-dark , includePaths:  C:\Users\sameergr\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\src\ar\src-scaffold\ionic\scss
[16:01:17] debug: [twx-studio:themeManager] Building twx-dark-theme-designtime.css
[16:01:17] debug: [twx-studio:themeManager] Building twx-dark-theme.css
[16:01:17] debug: [twx-studio:themeManager] Building twx-light-theme.css
[16:01:18] debug: [twx-studio:themeManager] building system-widget-extensions-designtime.css
[16:01:18] debug: [twx-studio:themeManager] building app-designtime.css
[16:01:18] debug: [twx-studio:themeManager] building app.css
[16:01:18] debug: [twx-studio:themeManager] building system-widget-extensions.css
[16:01:18] debug: [twx-studio:themeManager] copying css files for selected theme twx-light
[16:01:18] debug: [twx-studioSmiley TonguerojectHelper] onBuild
[16:01:18] info: [twx-studioSmiley TonguerojectHelper] Building ves-ar-extension app: FacilityPlantNew
[16:01:18] Mon, 16 Jan 2017 10:31:18 GMT ar-extension:gulp-shared clean
[16:01:18] debug: [twx-studioSmiley TonguerojectHelper] pathDir C:\Users\sameergr\Documents\ThingWorxStudio\Projects\FacilityPlantNew
[16:01:18] debug: [twx-studioSmiley TonguerojectHelper] scaffoldDir C:\Users\sameergr\Documents\ThingWorxStudio\Projects\FacilityPlantNew\src-scaffold
[16:01:18] debug: [twx-studioSmiley TonguerojectHelper] copySrc
[16:01:18] Mon, 16 Jan 2017 10:31:18 GMT ar-extension:gulp-shared copySrc
[16:01:18] debug: [twx-studioSmiley TonguerojectHelper] buildApp
[16:01:18] Mon, 16 Jan 2017 10:31:18 GMT ar-extension:gulp-shared build
[16:01:18] Reloading Browsers...
[16:01:18] debug: [twx-studio:sockets] EMIT addProjectComplete
[16:01:18] debug: [twx-studio:sockets] EMIT updateProjects
[16:01:18] Mon, 16 Jan 2017 10:31:18 GMT ar-extension:gulp-shared compile view contents
[16:01:18] no script for Home
[16:01:18] debug: [twx-studio:sockets] user disconnected
[16:02:23]  [0mGET /design/FacilityPlantNew  [32m200  [0m0.977 ms - 2122 [0m
[16:02:23] debug: [twx-studio:sockets] user disconnected
[16:02:24] debug: [twx-studio:sockets] a user connected
[16:02:24]  [0mGET /%7B%7BviewType.imgPath%7D%7D  [36m304  [0m0.450 ms - - [0m
[16:02:24]  [0mGET /images/%7B%7Bw.name%7D%7D.png  [36m304  [0m1.257 ms - - [0m
[16:02:24] debug: [twx-studio:sockets] EMIT builderSettings
[16:02:24] debug: [twx-studio:sockets] EMIT updateProjects
[16:02:24] debug: [twx-studio:upgradeProject] upgradeIfNeeded FacilityPlantNew
[16:02:24] Mon, 16 Jan 2017 10:32:24 GMT ar-extension:upgrade No upgrade needed:  1.8.290 1.8.290
[16:02:24] debug: [twx-studio:upgradeProject] Project does not need an upgrade.
[16:02:24] debug: [twx-studioSmiley TonguerojectSettings] write project settings FacilityPlantNew
Please help me with the same.
1 ACCEPTED SOLUTION
Re: Multiple Issues with Thingworx Studio
Now I see from where it is coming, looks like there is some issue with your 'Node js' application that runs behind your local Studio. Did you modify/uninstall the application? The transition error (in your logs) deals with Node js. Also, Did you try accessing studio in a different browser?
Can you please make sure the node.js application is installed? Or I would suggest to try repair or re-install the node.js application. If you are using older version of Chrome, then try in the latest version.
Let me know,
Giri
14 REPLIES 14
Hello guys,
Please help me with this issue. I really got stuck up.
Sameer Singh Rathoud
Sameer,
did you follow the instructions in the email that announced the new version? It says: please uninstall ThingWorx Studio and install it from scratch (more or less). I had issues with auto-upgrades with an earlier version and when I followed the instructions it worked fine.
Cheers, moritz
Hi Mortiz,
Thanks a lot for your reply.
I have removed everything from my earlier installation and did the fresh installation, Thingworx studio got opened once, but I was not able to drag anything in the 3D canvas section (model, thingmark etc), so I have reloaded the page and now everythng gone again.
When I click on my created experiences, it show as:
Please help.
By saying Fresh Install, do you also mean creating a Fresh project??
If you are using project from previous version, I would suggest - Exit the Studio application, Navigate to the ThingWorxStudio project directory -> Projects -> <project name>, Delete all the files EXCEPT "SRC, CSS, EXTENSIONS and appConfig". Restart the studio application, which will recreate all the directories and files. Now Open the Project, let me know if you still see the problem.
NOTE: Before deleting project directories and files, take a backup of the files (to be on safe-side).
Giri
Hi Giri,
Thanks for your response.
From fresh install I meant I have removed all the projects and Thingworx installation from my machine and ran the fresh setup.
I am really not very much concerned about my earlier projects. I just wanted Thingworx Studio should get opened on my machine. But only thing I see is:
Please help. I am really blocked.
Thanks in advance.
Sameer,
Looks fuzzy and puzzling!! If it is a fresh install, it shouldn't show this problem, especially the Debug_FD one. Make sure you have HOME or USERPROFILE env variables are inplace. you tried Exit application, is it correct?
-Giri
Hi Giri,
I have USERPROFILE in place, but dont have HOME env variable.
what HOME should point to?
Apart from this I have tried to run the ThingWorx Studio on IE as well, and tried on crome after reseting all the setting and removed all the extensions from the browser, but still no success.
Please help.
Thanks and Regards,
Configuring USERPROFILE variable should suffice. Studio looks for either of them.
Looks very strange!! Can you please try 'Inspect element' (Chrome dev tools) to debug/inspect on that page? Do let me know if you see any errors/warnings in Console | network | security logs.
Hi Giri,
Thanks a lot again.
I think you pointed at right place. I have few errors in the consol.
They are as follow:
Uncaught ReferenceError: module is not defined
Error: transition superseded
    at $StateProvider.$get (http://localhost:3000/js/main-production.js:16146:42)
    at Object.invoke (http://localhost:3000/js/main-production.js:22625:19)
    at http://localhost:3000/js/main-production.js:22419:37
    at getService (http://localhost:3000/js/main-production.js:22566:32)
    at injectionArgs (http://localhost:3000/js/main-production.js:22591:58)
    at Object.invoke (http://localhost:3000/js/main-production.js:22617:18)
    at http://localhost:3000/js/main-production.js:25726:43
    at forEach (http://localhost:3000/js/main-production.js:18140:20)
    at Object.<anonymous> (http://localhost:3000/js/main-production.js:25724:13)
    at Object.invoke (http://localhost:3000/js/main-production.js:22625:19) Possibly unhandled rejection: {}
Error: transition prevented
    at $StateProvider.$get (http://localhost:3000/js/main-production.js:16147:41)
Error: transition aborted
    at $StateProvider.$get (http://localhost:3000/js/main-production.js:16148:39)
Error: transition failed
    at $StateProvider.$get (http://localhost:3000/js/main-production.js:16149:38)
TypeError: Illegal invocation
    at Object.info (main-production.js:10310)
    at resetDebug (main-production.js:10367)
    at Scope.$digest (main-production.js:35597)
    at Scope.$apply (main-production.js:35863)
    at bootstrapApply (main-production.js:19624)
    at Object.invoke (main-production.js:22625)
    at doBootstrap (main-production.js:19622)
    at Object.bootstrap (main-production.js:19642)
    at HTMLDocument.<anonymous> (main-production.js:9936)
    at fire (third-party.js:3182)
    at n.wrapper (main-production.js:12203)
    at n.emit (socket.io.js:2)
    at n.onevent (socket.io.js:3)
    at n.onpacket (socket.io.js:3)
    at n.<anonymous> (socket.io.js:3)
    at Object.debug (http://localhost:3000/js/main-production.js:10317:35)
    at http://localhost:3000/js/main-production.js:1956:13
    at processQueue (http://localhost:3000/js/main-production.js:34431:37)
    at http://localhost:3000/js/main-production.js:34475:27
    at Scope.$eval (http://localhost:3000/js/main-production.js:35755:28)
    at Scope.$digest (http://localhost:3000/js/main-production.js:35569:31)
    at Scope.$apply (http://localhost:3000/js/main-production.js:35863:24)
    at n.<anonymous> (http://localhost:3000/js/main-production.js:12218:22)
    at n.onack (http://localhost:3000/socket.io/socket.io.js:3:6057)
    at n.onpacket (http://localhost:3000/socket.io/socket.io.js:3:5417) Possibly unhandled rejection: {}
WARNING: Tried to load angular more than once.
    at Object.info (canvas-main-production.js:10318)
    at resetDebug (canvas-main-production.js:10375)
    at m.$digest (angular.min.js:145)
    at m.$apply (angular.min.js:148)
    at angular.min.js:21
    at Object.invoke (angular.min.js:43)
    at c (angular.min.js:21)
    at Object.Mc [as bootstrap] (angular.min.js:21)
    at HTMLDocument.<anonymous> (canvas-main-production.js:1648)
Failed to parse SourceMap: http://localhost:3000/sass
Please help.
Thanks and Regards,
