Native variables in STYLES (CSS)
Level 8
Hello friends,
is it possible to configure the Vuforia Studio to support native variables in css?
Something like this:
:root {
--color: 240, 240, 240;
.bg-red{
background-color: rgba(var(--color), 0.5);
In present time must write unnecessarily complicated code because:
thank you for every post.
Tomas
Tags (2)
Re: Native variables in STYLES (CSS)
Tomas,
I'm not sure CSS Custom Properties (native variables) can be used in Studio, however you can include SASS syntax in the Application STYLES file: the file will be built to a css file using a SASS processor.
So, you can do something like this:
$color: rgb(240, 240, 240);
.bg-red {
  background-color: $color;
  opacity: 0.5;
The CSS Custom Properties syntax is flagged by the parser as incorrect: I can't say whether that's just a parser issue or the processor itself doesn't support it.
SASS provides features such as:
  • variables
  • nested selectors
  • mixins (reusable groups of CSS declarations, with optional parameters)
  • inheritance (share a set of CSS properties from one selector to another)
  • operators (to do math within a CSS)
HTH,
Alessio
