Phantom Display from Creo Illustrate to Thingworx Studio
tdevasagayam
Is there any way to make solids/surfaces as Phantom (Creo Illustrate - Object Display Style) in Thingworx Studio?
Though I make a solid phantom in Creo Illustrate, after importing into Thingworx Studio could not see that.
Thadeus.D
1 ACCEPTED SOLUTION
Hi Thadeus, There does not seem to be a Phantom option withing Studio. You can use a Model Item to isolate the part and then change the opacity/transparency of the part.
