I was having trouble with Robot Arm Tutorial # 2.
The JavaScript that is executed when the service is called after the service is called does not work.
If you remove and re-add the external data RobotArm1.GetProertyValues, the script will work.
It does not mean that the service does not work.
This is because the value is updated every 3 seconds.
Do you know why?
Warm Regards,
SeonHo
@CHASEONHO Are you facing this issue every time or is a one-time issue. As you mentioned the script is working so not sure if you need assistance.
Two of 10 people have had this problem.
@CHASEONHO Since it is not an issue for all and every time, I do not believe there is an issue with the service code. Are there any errors logged on 2 TWX instance where the issue occurred? We might get some insights about the cause of the behavior observed.
-Durgesh
