Selecting a sub-assembly in vuforia-studio using 'model-item' widget
venkatraj
I've a top-assembly with five sub-assemblies, which i added into studio as .pvz file. There I want to play with the sub-assemblies individually (example: a button to change the transparency level of one sub-assembly alone), so I dropped the 'model-item' widget on my model. But it picked only one single part. Converting each sub-asembly into individual .pvz will work, but is there any way to pick a sub-assembly after importing the top level as a single model.
Thanks!
1 ACCEPTED SOLUTION
sdidier
(To:venkatraj)
In Vuforia Studio, the Model Item has a field named Component Occurence.
With this field we can control which Component of the Assembly to use.
The solution to find quickly, the path of occurrence is to use Creo View and to follow these steps :
  1. In Creo View, open the pvz file
  2. In Viewables tab, in Model list, click the Default View itemCreo_view_viewables.png
  3. In the Model tab, in the tree, select the sub Assembly, Part or Component wantedcreo_view_model.png
  4. In the Root tab, scroll down until to see the Part ID Path setting. It is the same value to use in Vuforia Studiocreo_view_part_id_path.png
Best regards,
Samuel
sdidier
(To:venkatraj)
Best regards,
Samuel
venkatraj
(To:sdidier)
Excellent!!! It worked. Thanks.
