ThingWorx Composer not showing any entities
I am getting the above error while starting the composer.
Can anyone please check internally?
Thanks & Regards,
Dipika Sengupta
9 REPLIES 9
Re: ThingWorx Composer not showing any entities
Dipika Sengupta​,
Could you make sure if your user session is time out? Try to log out and log in again see if the issue persists?
Br,
Anna
Hi Anna An​,
I have tried logging out and logging in several times. But the same problem persists.
Dipika
Hi Dipika Sengupta​,
Is this a PTC hosted instance (Trial or Commercial) or local instance?
If it is a PTC hosted instance (Commercial); I will suggest you to open a case with PTC for this issue.
Ankit Gupta
Hi Ankit,
This is the trial instance only.
Dipika
If this is the hosted trial instance, try to login developer.thingworx.com and check your trial server status:
Try to Start Foundation Server and see if issue is gone.
Br,
Anna
Hi Anna An
This not the account I am using. my id is dipika.sengupta@in.abb.com.
This is the page I am getting.
Dipika
Hi Anna An​,
This is related to ThingWorx connected with ThingWorx Experience Service.
I will send a mail internally to concerned Team to check.
Ankit Gupta​,
Wow I just noticed that from the snapshot.
Thanks for letting me know.
Br,
Anna
