I cannot connect to Experience Service with my tablet.
I've installed Experience Service for SSL.
I can set and validated Experience Service in thingworx studio Info.
Also can preview and can call services of things that I made in thingworx core.
After I published this project and check with tablet(android, ipad),
I've got "ThingWorx Experience Service Connection Error" message. (Unable to connect to an Experience Service. Check your settings or contact your Administrator)
Of course I set the exact same URL for Experience Service as I set in thingworx studio.
Also I check with chrome in Tablet with ping to Experience Service (https://xxx:2019/ExperienceService/ping).
So, what should I do in this case?
and is there any ways to check logs in thingworx view?
Please follow the below steps to install the certificate in mobile or tablet:
Hi @dwie,
Could you please confirm the below details:
If the experience service is not registered with GXI, then you need to install self signed certificates in the Tablet to connect to the Experience Service from ThingWorx View App.
@ytella Thank you for the answer, and as you said, the experience service is installed on-premiseand is not registered with GXI. Could you give me guidance or website how to install self signed certificates in the Tablet.
I'm using iOS 11.2.6 and Android Tablet.
