Thingworx studio authentication issue
Regular Member
I have installed thingworx studio trial version (30 days trial period). When i am trying to publish the project or trying to preview it, it's asking for a "Authentication Required" pop-up. After giving the credentials, it is asking for the same authentication again and again. Attaching the screenshot on the same. Also i am using the same credentials to login to my studio account and it is taking correctly over there.
same authentication is being asked again and again when i am trying to access the thingworx cloud Iot platform using the experience server url as:
ES: https://icbeewyj.studio-trial.thingworx.io
Thingworx iot platform: https://icbeewyj.studio-trial.thingworx.io:8443/Thingworx/Composer/index.html
Is there any problem with the installation. I am trying all these steps using my public network( phone as well as my home wifi router).
Please help me.
Regards
Tarun
Re: Thingworx studio authentication issue
Hi Tarun, the credentials you use for logging into the portal should work for publishing. Can you please share your Studio log.
Adding the log file
Regards
Tarun
I am having the same issue here. Did you manage to solve the issue? I have also attached the log files in case this will help in any way.
