I have creo part of motor which assembles and disassembles.I used this inside 3d model widget when i publish the page it doesn't disassemble or assemble.Is there any thing i am missing?
Qadir umar: I believe you have selected and saved the Resource and Sequence URL under Model properties. Is there any animation and what format you are using? Could you please also share studio version and logs to review the issue.
-Durgesh
Hi Durgesh, I don't have .pvi file of the creo file, which we bind with Sequence URL of Model property.Can you tell me how can i create its .pvi file.I renamed the .pvz file to .zip file then i extracted it,i get .pva files,still didn't get any .pvi file.
Qadir umar: I believe renaming .pvz to get .pvi will NOT work. I will check on this and get back to you or may be leave it for my Creo expert colleagues to answer your question posted under thread Create Pvi file of Pvz file.
-Durgesh
Qadir umar: Please refer to Giri's last comment on post : Create Pvi file of Pvz file and request to mark it helpful or correct answer which will help others to know that this thread has a resolution and stands closed.
