I am not able to publish the experience in trial version of vuforia studio.It gives me popup to enter my user credentials. In spite of entering the UN and PWD more than 20-30 times, still not able to publish.
Please help!!!
Attached Log for Reference.
Deepika M
Thank you for opening this post on community.
Could you please provide me the below mention things so that i can check this:
1) Your Experience service URL.
2) Username by which you login on studio.thingworx.com
3) Screenshot when you login on studio.thingworx.com
We need to check if your trail version is still active or has expired.
Do let me know in case of any question.
Regards-Mohit
Are you able to access https://4fe05c07d69450b2.studio-trial.vuforia.io/ExperienceService directly and log in? These would be the same credentials used to sign up for the trial. Are you using Studio behind a corporate proxy?
Same issue need help unable to publish
In the error log file, we found this error multiple times :
[2018-10-31T11:46:53.274Z] error: [twx-studio:proxy] Proxy error { Error: connect ETIMEDOUT 54.164.59.221:443 at Object._errnoException (util.js:992:11) at _exceptionWithHostPort (util.js:1014:20) at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1186:14) code: 'ETIMEDOUT', errno: 'ETIMEDOUT', syscall: 'connect', address: '54.164.59.221', port: 443 } null 200
This article is refering about it, as well thislast thread in the forum :
https://www.ptc.com/en/support/article?n=CS269453
https://community.ptc.com/t5/Studio/Unable-to-publish/td-p/596273
I would recommand to follow the same investigation steps and report in this thread the results :
It will help to troubleshoot.
Thanks you,
Samuel,
Best regards
