Unable to publish experience
Level 7
I am not able to publish any experience. Attached log for reference.
Re: Unable to publish experience
@MSD2 From the error message it appears there is some issue with your proxy configuration within Studio. Could you please review the proxy setting in Studio following below options-
PFA.
-Durgesh
Durgesh,
Please find the screen-shot of my settings.
@MSD2: Could you please confirm if you are using proxy server and if yes, then enter your proxy server detail in the setting and try publishing.
-Durgesh
Durgesh,
I dont think I am using a proxy server. I was using default settings and it worked fine till couple of weeks back.
Dhinesh
@MSD2 Dhinesh - Thank you for confirming on proxy.
Could you please login to Studio Trial and confirm if your trial instance is active, not expired ? Also, share the userID been used so that I can check internally if there is any issue with your provisioned Trial instance.
-Durgesh
-Durgesh
Durgesh,
The instance got expired.
Also please let me know how to find UserID?
@MSD2 UserID is the "login ID /Username" used to enter Studio Trail portal. Post login please click "Contact Us" to request Trial extension.
PFA.
-Durgesh
Durgesh,
It seems the instance is active now. But I am not able to publish experience still.
Dhinesh
