Is there a Glossary of terms used in Vuforia Studio? For example, how is a public view defined and how it is different from a registered view.
Thank you!
public view: You don't have to type in login credentials in Vuforia View.
Registrated /private : You have to sign in with username and password. The data is sent to thingworx. If a user with the filled in data exists, he is able to use the experience. You can set user profiles in thingworx, and give those user profiles different rights or views.
@ocarvatchi As far I know we do not have an official documentation for Glossary of term however work is already in progress to get sometime available to Vuforia Studio users.
If there is something specific or query then let me know will try to get details which is available at the moment.
-Durgesh
