Vuforia Studio Scripting
Participant
Is there a way with in Vuforia Studio to access the list of uploaded resources via scripting in Home.js? I'm struggling to find in depth documentation on the scripting capabilities within Vuforia Studio. I know the parameters can be accessed by $scope.app.params so I'd think the resources would also be able to be accessed similarly but the syntax isn't intuitive and without documentation it's difficult to figure out.
Re: Vuforia Studio Scripting
Yes, you can use the resources within Home.js. What are you trying to do?
As an example, you can update sequences of a model by doing the following:
$scope.view.wdg['model-1']['sequence']='app/resources/Uploaded/Illustration/<PVI file name>';
In the Application page, you can reference uploaded resources using $resources.
Example: background-image: url(#{$resources}/Uploaded/image.png)
Great thank you this is helpful information. Could you explain your bottom example a little? What is considered the 'Application page'? Is url a specific url or is it literally url?
I am trying to use a script to assign each model uploaded as the resource for a model in my scene. Is there a way to iterate through each of the uploaded items?
The Application page is for writing CSS - you can reference uploaded resources like images to be used within your class.
I think this community post may be helpful: https://community.ptc.com/t5/Studio/get-list-o-file-from-Uploaded/m-p/603367/highlight/false#M5396
It discusses using $http to read in a json file of all the resources.
