Vuforia studio authentication issue - Unable to login
MrGiuliano
6-Contributor
I have noticed many others have flagged this issue but I cant seem to find a resolution in all the posts.
I have installed thingworx studio trial version 30 days trial period. When I'm trying to publish the project  it's asking for a "Authentication Required" pop-up. After giving the credentials, it is asking for the same authentication again and again.
Below is some code from the log.
Any help would be appreciated.
Kind Regards
Giuliano
Username : mr.ora.holo@gmail.com
[06/11/2018 19:12:30] warn: [twx-studio:gitUtils] nodegit is not installed.
[06/11/2018 19:12:36] info: [twx-studio:versionCheck] Version Check will use the update location: https://studio-download.vuforia.io/downloads/Studio.application
[06/11/2018 19:12:36] ar-extension version 8.3.0.3345 (1.26.1125)
[06/11/2018 19:12:37] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[06/11/2018 19:12:42] GET /home 200 33.967 ms - 3973
[06/11/2018 19:12:47] GET /libthingview_wasm.wasm 200 136.873 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::projectType.imgPath%7D%7D 200 4.080 ms - 3973
[06/11/2018 19:12:51] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 200 5.899 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::view.imgPath%7D%7D 200 5.845 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7BviewType.imgPath%7D%7D 200 6.934 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::w.image%7D%7D 200 8.307 ms - 3973
[06/11/2018 19:12:51] GET /libthingview_wasm.wasm 200 1.714 ms - 3973
[06/11/2018 19:13:57] GET /api/switch 401 6.531 ms - -
[06/11/2018 19:13:57] GET /api/switch 200 0.326 ms - -
[06/11/2018 19:13:58] GET /ExperienceService/viewcommandhost 200 680.003 ms - 24
[06/11/2018 19:14:59] info: [twx-studio:projectHelper] Building ves-ar-extension app: X7-2
[06/11/2018 19:15:12] info: [twx-studio:projectSettings] Notify preview windows: private-room-X7-2
[06/11/2018 19:15:12] GET /api/switch 200 0.383 ms - -
[06/11/2018 19:15:13] POST /api/publish/ 401 814.534 ms - -
[06/11/2018 19:15:30] POST /api/publish/ 401 381.222 ms - -
Thank you for the log file. I see you were able to auto-configure your instance without issue. The credentials used for auto-configure should be the same for validating/publishing. Are you using all lowercase when trying to validate/publish? These items are case sensitive. Have you tried MR.Ora.Holo@gmail.com as your username?
6 REPLIES 6
Are you able to validate the Experience Service without issue? You can do this under the 'info' tab of your experience.
MrGiuliano
6-Contributor
(To:tmccombie)
Hi there,
That's for the reply.
I've gone to the info section.l selected validate. The field is populated with the trial URL. Clicked on validate and it asks me to sign in. I sign in but face the same issue with the sign in screen repeatedly popping up after I click on submit.
Many thanks
Please share your entire log file. This will help to determine root cause and a solution.
MrGiuliano
6-Contributor
(To:tmccombie)
Thanks for coming back to me. I have attached the log file.
When the login screen pops up and I enter my username and password. It will keep popping up asking for it to enter. There are no errors unless I click on cancel I will then see a message Oh no publish failed Make sure I'm using the correct username & password.
Many thanks in advance!
MrGiuliano
6-Contributor
(To:tmccombie)
It works Smiley Happy
I'm sorry it was such a silly thing. I should have checked beforehand but didn't think the case mattered with a username.
Thanks for investigating and providing the feedback !!
Kind Regards
G
