What is ThingMark ?How can i get it?
Level 1
hi ,
     I have installed the thingworx studio. when i try to publish the view it asks me Thingmarks and Thingworx experience service I don't know, what it is?  how can i get the thingmarks and Thingworx experience service.In case, if i have to install it , share the installation procedure.
Qadir
Message was edited by: Sushant Pandey Changing it to ThingWorx Studio
Tags (1)
28 REPLIES 28
Re: What is ThingMark ?How can i get it?
Hi Qadir, they are somewhat identical to a QR code, uniquely identifying the device/machine against which they are used. If you are starting afresh with ThingWorx Studio, believe this could be very useful blog for you Augmented Reality Applications - Vuforia SDK / ThingWorx Studio - What is what?
Additionally, i would strongly recommend you to go through the Getting Started guide for ThingWorx Studio
Hope this helps.
Hi Sushant,
    I am new in Thingworx studio.I have gone through the document .I have created a project when i try to publish it , it requires thingmarks. What will i have to do in order to get thingmarks.
Qadir umar​,
Please register at ThingWorx Studio – Unleash your imagination. for the trial version of ThingWorx Studio. Once approved you will get a welcome e-mail with the Experience Server Url. Then you can configure your ThingWorx Studio which includes 3 ThingMarks for use in your Project.
Do let us know if you have any further Queries.
Hi Ankit,
     After Registering I got approval to download the trial version the of Thingworx Studio,I didn't get any Experience Server Url.
Hi Qadir umar​,
Please share your email used for Registration, I will check internally regarding the Status. If the Experience Server is already assigned I will request and forward the URL on your Email.
Ankit Gupta
Also, ThingWorx Studio is correct Space to post queries related to ThingWorx Studio.
Hi Ankit,
        I have used quadir.umar@itcinfotech.com ​registration.
Qadir Umar
Hi Qadir umar​,
Before I check internally; could you please do following:
Open ThingWorx Studio Home page and on Top Right; you will see three Dots (...).
Click on ... -> Portal login.
Enter your Studio Credentials and click on Configure.
It will configure your Experience Service URL and will also download the ThingMarks which you can use in your Project.
To confirm; go to ... -> Settings. Default ThingWorx Experience Service URL should show the Experience Server URL.
Do let me know if it doesn't work; we will check internally with the Team.
Hi Ankit,
      I am telling you what i have done till now, I registered in Thingworx Studio to download trail version. once i got confirmation mail , I downloaded and installed it , After installation, Configure ThingWorx Studio Popup Opened.I entered the studio credential from which i registered.It gave error. So i clicked on link, No thanks, I will configure ThingWorx Studio manually, then Welcome To ThingWorx Studio Page Opened in which 2 projects were listed. I tried to Publish existing Project, it started to ask me ThingMarks.
Now I restarted the System  and tried what you said,  I clicked on ... -> Portal login.I entered studio credential from which i registered. I clicked on Configure, it gives error Auto configure failed. Check log for errors. Then clicked on ... -> Settings. In Default ThingWorx Experience Service URL , "http://localhost:3000/" is appearing. when i publish the existing project it asks me username & password . I entered my studio credentials here . it gives error. I don't know ThingWorx Experience Service credentials so i had entered Thingworx Studio Credential. I don't know the ThingWorx Experience Service URL is correct or not.
Qadir
