Now you have to select an object and bind the gesture or voice command to it. Can it be reversed? Say a command is predefined and object is a variable?
I would want to say "move this left" and select an object, and the binding will happened on the bg
You can bind a voice command/gesture to a View (i.e., Home View for example) and navigate between two views. Technically even the adhoc should do some action. Let us know if you are looking for a specific usecase.
