Hi all,
It will be usefull to have a OK check at the end of animation.
Wich code is necessary?
Sure,
One way would be to create the sequence in creo illustrate - and there request validation for the last step.
This will trigger a function that you can reuse in studio e.g. to show a popup or do something else with it.
Martin
Hi Martin,
thanks for your help.
Now it's easier to understand when the animation is over
Hi Martin,
forgive me but I find a trouble. In the same file I have four figure with one animation each.
I have bind model and toggle-botton like you explain.
First animation it's OK. At the end of it toggle-botton unhided.
After that, second and other animation doesn't run.
With prior .pvz ( without Acknowledge) the trouble doesn't exist.
Where the problem can do?
Thanks again
Alberto
Well thats not a bug at least.
put the acknowledge per sequence, as you wish.
Changing sequences is definitely not affected by this.
Martin
