Hi all,
is it possible to use an image as a tracking target or does it only work with Vumarks?
thanks.
Benni
Benjamin Staiger : You will need Vumarks ( now ThingMarks ) however it is possible to have custom Thingmarks.
-Durgesh
As Durgesh mentioned, you will NEED a ThingMark - but you should be able to customize them.
However if there are tracking requirements outside of the ThingWorx context, check also this Blog post:
Augmented Reality Applications - Vuforia SDK / ThingWorx Studio - What is what?
The basic Vuforia SDK will allow you to create unique experiences by tracking any object / shape.
For ThingWorx Studio however, those objects are the ThingMarks as they also hold specific object IDs to relate the distinct "instance of an object" with the actual data in the ThingWorx platform.
I hope this helps...
Cheers,
Michael
