Hi all,
What is the procedure to manipulate or rotate a model that is viewed in the HoloLens TWX View? Is the rotation a sequence step or is there a method of getting a gesture to trigger a model rotation?
Brian
I have used a simple approach to rotate the model . :
Create Application parameter RotationY , bind it with the Y Rotation in the model
Add JS to for example Swipeleft event : app.params["RotationY"]= app.params["RotationY"] - 90 to rotate the model 90 Deg on Swipeleft
Thank you very much for the help Francois! I'll give this a go..
Brian
