请问怎样增加文本字体?How to add text fonts?
jchen-6
1-Newbie
你好,请问怎样增加文本字体?如能帮忙十分感谢。
Hello, how can I increase the font size? Thank you for helping me.
1 ACCEPTED SOLUTION
if you add the following option into config.pro file, then you will see all Windows fonts in Drawing mode.
PRO_FONT_DIR C:\Windows\Fonts
Alternatively, you can copy .ttf files from C:\Windows\Fonts directory to Creo2_loadpoint\Creo 2.0\Common Files\Mxxx\text\fonts directory.
If you want to set text height in the drawing, then:
  • select text
  • press right mouse button
  • use Properties command
  • set height on Text Style tab in dialog window
Martin Hanak
Martin Hanák
15 REPLIES 15
please provide more details (text, picture)...
Martin Hanak
Martin Hanák
Hello, I want to add the font style in the drawing,
Thank you
  • select text
Martin Hanak
Martin Hanák
How to add the option C:windowsFonts pro_font_dir
I might not have added
Open Creo2_loadpoint\Creo 2.0\Common Files\Mxxx\text\config.pro in Wordpad, add the above mentioned line at the end of the file and save it. Restart Creo.
Martin Hanák
Hi, the problem has been solved, thank you very much.
Hi Jack,
Are you looking to increase the font size of notes/text in the drawing or maybe the font size of the menus in the Creo window?
Please clarify what you are looking for.
Thank you,
Amit
Thank you
Hello, I want to increase the font style, thank you
Hi Jack,
In order to increase the font size in the drawing, you can do 1 of 2 things.
  1. To increase the size of individual text:
    1. Select the text > right-click > Properties
    2. Click the Text Style tab
    3. Un-check the Default check box next to Height
    4. Enter the desired value
  2. To increase the size of all the text on the drawing:
    1. File > Prepare > Drawing Properties
    2. Detail Options > change
    3. Option - text_height; Value - desired value, e.g. 0.75
    4. Add/Change > OK > Close
    5. Repaint the drawing screen
Amit
caswq
1-Newbie
(To:jchen-6)
you just click Edit>Font> increase or Decrease
jchen-6
1-Newbie
(To:caswq)
I can't find the Edit
Hi Jack,
I just wanted to check if my suggestions above helped you get the desired result.
If not, please let me know any further information, that would be useful to help me find the answer.
Amit
Hi, Amit
My problem has been solved, I began to express the wrong, very much for your help, really very grateful,
Thanks ,
Jack
Mahesh_Sharma
22-Sapphire I
(To:jchen-6)
Jack,
You may mark appropriate reply on this post as Correct Answer.
