10.2 Creo Search Results???
davehaigh
In 9.1 you get results in the model tree area and also in the main screen. Where are my results in the main screen????
[cid:image001.png@01CFBD1F.286A3A80]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
I exited Creo, cleared the cache in IE9 and then started Creo again. The search shows up in both windows. Appears to work for multiple searches.
However, when I went to the embedded browser to do a saved search, that worked but then the model tree search tab will no-longer update the embedded browser with the search results.
David Haigh
I spoke with the TSE Friday, and had a webex to show him the issue. He was able to reproduce it. Today he sent me an email with the following SPR, that's been known about since 10.1, as you can see the SPR says there are no plans to fix this issue in either 10.1 or 10.2.
I'm a little miffed that they don't see this as a problem and have no plans to fix it.
Document - CS107410
Document Information
Type
Article
Date Created
06-Dec-2012 09:16:37 EST
Date Last Updated
06-Dec-2012 09:25:17 EST
Document Details
Title
Search in Creo shows blank results window if Search in embedded browser was used before in Windchill PDMLink 10.1
Description
* Search in Creo shows blank results window if Search in embedded browser was used before
Applies To
* Windchill PDMLink 10.1 all datecodes
* Creo Parametric 2 M010 and M020
Cause
Resolution
* Reported to R&D as SPR 2159746
* Workaround: Temporarily switch to the workspace content in the Navigator and leave the Search of the embedded browser
SPR Information
Product
Windchill PDMLink
Module
Workgroup Manager for Pro/ENGINEER Wildfire
Reported Release
10.1
Reported Datecode
M020
Affected Platform
All
Resolution Status
Release
Status
Datecode
10.2
No Plans to Fix
10.1
No Plans to Fix
Related Documents
Type
Number
Status
Description
Case
12132739<">https://support.ptc.com/appserver/cs/view/case.jsp?n=12132739>
On Hold
In 9.1 the Creo search tab in the model tree area returned results in the model tree and in the main window. In 10.2, the results in the main window are not showing up. The window comes up but it's blank. What's up with that?
David Haigh
