Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I exited Creo, cleared the cache in IE9 and then started Creo again. The search shows up in both windows. Appears to work for multiple searches.
However, when I went to the embedded browser to do a saved search, that worked but then the model tree search tab will no-longer update the embedded browser with the search results.
I spoke with the TSE Friday, and had a webex to show him the issue. He was able to reproduce it. Today he sent me an email with the following SPR, that's been known about since 10.1, as you can see the SPR says there are no plans to fix this issue in either 10.1 or 10.2.
I'm a little miffed that they don't see this as a problem and have no plans to fix it.
Document - CS107410 Document Information Type
Article
Date Created
06-Dec-2012 09:16:37 EST
Date Last Updated
06-Dec-2012 09:25:17 EST
Document Details Title
Search in Creo shows blank results window if Search in embedded browser was used before in Windchill PDMLink 10.1
Description
* Search in Creo shows blank results window if Search in embedded browser was used before
Applies To
* Windchill PDMLink 10.1 all datecodes * Creo Parametric 2 M010 and M020
Cause
Resolution
* Reported to R&D as SPR 2159746 * Workaround: Temporarily switch to the workspace content in the Navigator and leave the Search of the embedded browser
In 9.1 the Creo search tab in the model tree area returned results in the model tree and in the main window. In 10.2, the results in the main window are not showing up. The window comes up but it's blank. What's up with that?
