These two options seem to accomplish the same thing. The 2D option was introduced back in Creo Parametric 1.0, while the SKETCHER option has been around since WF3. I'd like to eliminate redundant settings. Any reason to keep SKETCHER_PALETTE_PATH around anymore? We're well beyond CP1 at this point.
I think, option sketcher_palette_path can eliminate. If i remember correctly, it was been removed from active configs from Creo 3.0 M0180/Creo 4.0 M070
