3D parameters uddate to 2D table
KI_10190013
2-Explorer
I am using Creo Parametric Release 4.0 and DatecodeM090
When you change the parameters of the 3D model, normally
The drawing parameters are also changed, but the changes are no longer reflected.
As an example, I wrote "TEST" in PART_NANE in the 3D model,
The "MODEL 50 ID INPUT" previously described in the 3D model parameters remains.
The 3D reference has not changed, but once again the 3D parameter
Is it possible to reflect the contents in the drawing?
please pack you model+drawing into zip file and upload this zip file.
Martin Hanák
Check the end of your parameter to see if it has a :d at the end of it. If it has that it will pull the parameter from the drawing instead of the model. All you will need to do is delete that off the end.
