3GB Switch on Win7 32
msteffke
Can the 3gb be set on Win7 32bit? If so is the command setting it the
same as XP? I suspect that its not.
Mark Steffke
To enable the 3GB switch on Windows Vista? or Windows 7:
1.Right-click Command Prompt in the Accessories program group of the Start
menu. Click Run as Administrator.
2.At the command prompt, enter "bcdedit /set IncreaseUserVa 3072"
3.Restart the computer.
To disable the 3GB switch:
1.Right-click on Command Prompt in the Accessories program group of the
Start menu. Click Run as Administrator.
2.At the command prompt, enter "bcdedit /deletevalue IncreaseUserVa"
Best Regards
Chris Collinson
CAD Administrator
I once read that this setting is no longer required in Windows 7, as it is already the default.
However, I have not confirmed this.
Gerry
In Reply to Mark Steffke:
msteffke
(To:msteffke)
Thanks so far, have another tiny question:
in xp we would set /3gb, then we had to add userva=2800 for the video
card, or else the machine would not reboot.
Would the equivalent be "bcdedit /set IncreaseUserVa 2800" ??
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
msteffke
(To:msteffke)
This seems to have worked. Thanks all.
Mark Steffke
