3gb switch
wfalco
3gb switch
All,
Is setting the 3gb switch required for Windows 7?
If so - can you point me to instructions on how to do this?
WayneF
wfalco
(To:wfalco)
Forgot to mention - this is for 32 bit.
wfalco
(To:wfalco)
Every on agrees that 64 does not need it. Do I need it on 32 Win 7? On
Dell Latitude E5510.
I'd like to add more memory, but need to know if the switch needs to be
set so the new memory will be recogonized.
gwalker
(To:wfalco)
A 32-bit system will recognize up to 4GB of RAM regardless of the 3GB switch setting. Actually, on XP, it will show 3.5GB in the properties even though the system has 4GB.
I recommend NOT setting the 3GB switch if you are running Windows 7 32-bit with 4GB of RAM or less. On Windows XP, the 3GB switch can cause some graphics problems that most users would not appreciate.
If you need more than 4GB of RAM you MUST have a 64-bit system.
TomU
(To:wfalco)
The 3GB switch IS needed if you want any one process to be able to access more than 2GB of virtual memory (on a 32 bit machine). From another website:
To enable the 3GB switch on Windows Vista™ or Windows 7:
1. Right-click Command Prompt in the Accessories program group of the Start menu. Click Run as Administrator.
2. At the command prompt, enter "bcdedit /set IncreaseUserVa 3072"
3. Restart the computer.
To disable the 3GB switch:
1. Right-click on Command Prompt in the Accessories program group of the Start menu. Click Run as Administrator.
2. At the command prompt, enter "bcdedit /deletevalue IncreaseUserVa"
