A alert message wen I run creo 4
Antonio_Serrano
8-Gravel
Hi good afternoon, I´m using a educational license of PTC creo 4, when I run the  program I see these alert.
How can I solve it?
thanks for your time.
Click YES and ignore it.
Yes, I do it, but whenever I run the program I see the alert.
So the question is if I can change any configuration in my system for avoid to see the alert
TomU
(To:Antonio_Serrano)
You can set a config option to change the default web page.
File > Options > Configuration Editor > Add > web_browser_homepage
Set it to some other website or just about:blank.
Save the change and the next time you open Creo this new page will load instead of the default one (with errors.)
I try your advise, but if I use these option I only add a new website in the webexplorer that load at the begging, the only option for avoid the message is deselect the option that I mark in the photo
the  web that produce the alert is these: https://www.ptc.com/community/creo4/academic/
