Hi all!
Does anyone have some hard facts how the ARX rendering enginee work?
I need info if the ARX engine are multi-core based (can use more than one RAM-core, example if using a computer with 4x4gb cores so in toital of 16 gb, and using windows 7 x64)
I also need info if ARX rendering module usese CPU+GPU?
And what kind of graphic-cards that are recomended.
I this info are avaiable anywhere please let me know!!
Kind regards,
Lars
here you can find System Requirements for Pro/ENGINEER Wildfire 5.0 and Creo Elements/Pro 5.0
If you are looking for a specific workstation: see HP8740w - it's really cool PC for your work ;o)
Vladimir
Hi!
Here are some extra info regarding the ARX module and how it works!
Questions and answears! ![]()
Here a Link to our Website…
http://www.ptc.com/products/creo-elements-pro/advanced-rendering
…and here the answers:
•I need info if the ARX engine are multi-core based (can use more than one RAM-core, example if using a computer with 4x4gb cores so in toital of 16 gb, and using windows 7 x64) -> Yes, ARX support multicore, the render engine is mental ray. For further information about mental ray take a look to the mentalimages webpage. (http://www.mentalimages.com/products/mental-ray/about-mental-ray/features.html)
•I also need info if ARX rendering module usese CPU+GPU? -> Yes, mentalimages is a Nvidia company and ARX is optimized for CUDA enabled GPUs.
•And what kind of graphic-cards that are recommended? ->see the PTC Website… http://www.ptc.com/WCMS/files/77552/en/proewf5.pdf
So the graphic-cards that are supported for Creo/Elements Pro are also supported as ARX - rendering extension.
Kind Regards,
Lars Fäldner
