We require an improvement so that Creo2.0 installation folder can be changed. "Creo 2.0" is no good.
Which folder is being named Creo 2.0? The folder/directory on disk or the one in the start menu?
Martin
Martin,
C:\ptc\Creo2_M010\Creo 2.0\Parametric\bin\parametric.exe
C:\ptc\Creo2_M010 ... the path entered during Creo 2.0 installation
Users do no like spaces in PATH.
Martin Hanak
Yes,
As Martin Hanak say ,We do not need "Creo 2.0 " in Path.
We can not compile the customized system.
We are at a loss of what to do.
Forever.We can not use the Creo 2.0 for drawing
Shinji Matsuda
I do not understand the Folder Name use the spaces in PATH.
Shinji Matsuda
Matsuda,
if you need some help, please describe your problem.
Martin Hanak
Dear Mr.Hanak
We have very many problem caused by spaces.
(Pro/toolkit complie error)
Let me give you one example.
PROTOOL_SRC = D:\PTC\Creo20\Creo 2.0\Common Files\F001\protoolkit
PRODEV_SRC = D:\PTC\Creo20\Creo 2.0\Common Files\F001\prodevelop
we can not create makefile.
also , PROTOOL_SRC = "D:\PTC\Creo20\Creo 2.0\Common Files\F001\protoolkit"
Best regards,
Shinji Matsuda
Matsuda,
I am sorry, I do not understand makefiles. I only know that path containing spaces must be enclosed into doublequotes. Maybe you can test, whether you can replace directory names containing spaces by their short names (you will get short name in command prompt window if you use command dir /X)
Try to replace your definition
by
PROTOOL_SRC = D:\PTC\Creo20\CREO2~1.0\COMMON~1\F001\protoolkit
Martin Hanak
Dear Mr.Hanak
Your advice really worked.
I finally got it straightened out.
Thank you so much.
Best regards,
Shinji Matsuda
