Added mapkeys not showing in Ribbon - Creo 1.0-m030
davehaigh
11-Garnet
I have three mapkeys I'm trying to add to the ribbon and they don't show up. Other mapkeys show up no problem.
If I create a new cascade. The cascade shows up in the ribbon.
[cid:image004.jpg@01CD083E.1FE83A80]
As soon as I add one of these mapkeys to the cascade, it disappears.
[cid:image006.jpg@01CD083E.1FE83A80]
If I add a different mapkey to the cascade, it shows up.
[cid:image009.jpg@01CD083E.1FE83A80]
Any ideas? The mapkey works if I type the key name.
The problem mapkeys are loading a config file to change the config option cleanup_drawing_dependencies.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
2 REPLIES 2
I have a workaround for the SPR.
Thanks to Olaf Corten, pointing out to me that the forward slash in the key name was the cause of the problem in the ribbon. The mapkey works when typed from the keyboard but you can't add it to the ribbon if it has a slash in the key name. The other thing he pointed out, that really helps with Creo, is you want to use cmdmgr_trail_output yes in your config.pro
I've also been playing around with where Creo stores the customizations to the ribbon. There are three possible locations. Creo will read all three.
1. The Creo loadpoint <--File has to be renamed
2. The Creo Cache <--The default location
3. The Startup Directory <--Requires a config option
By default the ribbon customizations are stored in a .ui file with this name:
creo_parametric_customization.ui
The Creo Cache Location
David,
Thanks for taking the time to summarise this little gotcha, I've been
trying to get this to work for a little while now and with this doc have
managed to do what I need, so thank you for this
Best Regards
Chris Collinson
CAD Administrator
