Is it possible to use part positions defined in a configuration for positions while defining an animation? This seems like it would be an obvious functionality to have however if I try to activate a configuration while defining an animation the animation editor closes. If I then go back to the animation editor with a configuration active I receive an error message that "When a configuration is active you cannot use this command".
