Sorry for all the post, but to those of you that have jumped to newer versions earlier, I now feel your pain.
Alt-W used to jump you to a command where you could choose another window.
I realize now that there is the search bar for commands where you can type in the old command and it will give you the new command. When typing in "Alt-W", it returns nothing. How do you switch between windows?
(It's going to be a long day!)
Thanks, Dale
I found the icon:
Not what is the hot key to activate the icon?
Thanks, Dale
Would anybody happen to have a list of these commands and what they do?
I didn't realise there were such shortcuts.
Neal
It's supposed to be like windows programs. So if you hit ALT-F, that's the file tab, then if you look at the drop downs or the icons, it shows a letter by each one indicating the key to get to that command.
This is the first level.
Is there one for the window icon circle above? (that you know of)
Take a look at the View tab. Alt + V, WN, 1/2/3/etc.
Push and let go of the ALT key and it shows you what is available. That's what I did in the image above, I should have mentioned that. It'll be some different for you based on your toolbar.
