Annoying information window
Newbie
Good morning!
I am working on a drawing which is doing something I have not seen
before. I am hoping someone can help me with this problem. Everytime I
open the drawing, go to another sheet, switch from the assembly to the
drawing, etc., this window pops up informing me that the quantity of a
couple of parts has changed. It is always the same two parts. The
window pops up even when I have not done anything to these parts or the
drawing.
I have seen this window before many times. It is a ridiculous
information window that I do not want to see. Normally this window
would pop up only once when you opened the drawing for the first time or
after you changed the quantity of parts in the assembly.
How do I stop this window from popping up? I think there is a config
setting for this. If so, what is it?
Mark
Re: Annoying information window
Does this window prompt you to verify any instances? Do you have a family table involved with this drawing?
Michael P. Locascio
