Anyone know the answer?
BillDaugherty
Thanks in advance for whatever help you might give. Where can I find a comprhensive list of all the config options in ProEngineer?
5 REPLIES 5
Search the PTC knowledge base for the following reference document numbers or select the links. There are different documents depending on the release you are interested in:
Thanks for that, you never know when I can use that info. I have saved it on my PC.
Regards
Chris
Hi Travis,
Does this list include the Hidden Config options??
e.g. "text_height_factor" is the hidden config option and it is not included here. Is there anyway I can know about all the hidden config options too??
Jay Shah
Here is a website you may also want to look at: http://www.proesite.com/.
If go to the utilities section and select the online utilities link there is one for the config.pro options. The utility also lists the hidden options if you want to try them out.
John.Pryal
(To:Kevin)
you can also try the pro-e help center, click help, help center, when the window appears, you will see books at the left hand, click this & you will see pro-e configuration, its a pdf document, its quite good actually, it details what is new, what has changed etc.
hope this helps
Regards
John
