Anyone knows how to switch Pro/E UI to Creo UI?
Currently, we use academic version Creo Element.
Config.pro ui_theme has only three options.
Widfire 5.0
Wildfire
Standard
Not possible!
The UI is dependent on too many things that have changed and is embedded into the code itself.
Maybe there is some confusion here. Pro/E Wildfire 5 was re-branded as Creo/Elements Pro when PTC decided to change the name of Pro/Engineer to Creo Parametric. Later, Creo 1 was released followed by creo 2, Creo 3, and soon Creo 4.
If you are using Wildfire 5 (also known as Creo/Element Pro) released in 2009, there is no way to make it look like the lastest release of the software.
