Assemblies Simplified Reps and Drawings
Newbie
Here’s my dilemma.
I have an assembly of parts. I made various simplified reps of the assembly to make a series of drawings. I’d like to be able to make a drawing of a particular part from the assembly instead of the part itself. The part is made with a “solidify” using surfaces in a skeleton part so I’d like to be able to use the skeleton dimensions on the drawing.
In this particular part, there are certain features that I want to exclude from the drawing. So I went into the part and made a simplified rep that excludes the features. In the assembly I substituted the master rep of the part for the rep that excludes the features.
My goal here is to try and eliminate the family table.
The problem that I seem to be having is that I’m unable to show dimensions in the drawing. I’m praying that it’s a config.pro option or some other simple fix.
I’m sending a simple assembly and drawing that illustrates my problem.
Thanks in advance for your help,
Sam
Wildfire 2.0
Datecode M180
