I would like to have more than one assembly placement set for a component that way I can switch between to view component in different positions. But the "New Set" is greyed out. I have to delete a set to add a new placement set. What is the problem.. a config setting?
The only time I've seen this happen is if a Set has references that are not defined or have been lost.
