@VS_10240999 wrote:
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
Hi Team, The bitmap image is attached in a drawing as an object but after check-in, it's not showing in creo view, and after checkout same drawing in creo its also not visible in creo.
set following config.pro option and save the drawing.
save_texture_with_model yes
Thanks for the reply.
already using save_texture_with_model yes.
