I am using Creo Parametric Release 6.0 and Datecode6.0.0.0
I want a .prt file modeled in CREO 6.0 to open in CREO 5.0. Is there any method available to export the .prt file so that it can be opened in CREO 5.0?
Note: I want to retain all the features while exporting.
<.prt file name> cannot be retrieved
To the best of my knowledge, Creo is not backwards compatible.
https://community.ptc.com/t5/System-Administration/Back-Compatibility/td-p/602675
The GCRI still works with Creo Parametric 6.0 and below to allow you to open Creo Parametric 6.0 files in 5.0. See https://www.ptc.com/en/support/article/CS34964.
