Batch file compare
Highlighted
Guest
Batch file compare
I would like to edit our iLink batch startup command to replace a file on
all the clients.
What do I add to a batchfile to know if it has already done the replace?
Vaughn McDaniel III
CAD/PDM Administrator
Windsor Industries
Englewood, CO
303.762.1800 x187
Highlighted
Batch file compare
Summary,
Thanks guys. I got what I need.
Vaughn McDaniel III
Windsor Industries
Englewood, CO
303.762.1800 x187
"Augeri, Jim (NM75)" <james.a.augeri@honeywell.com>
02/01/2008 10:14 AM
To
"Vaughn McDaniel" <->
cc
Subject
RE: [proesys] - Batch file compare
Vaughn,
Here is how I accomplish the same thing for our I-DEAS installations, and
a few other things.
Right at the top of the installation script, include something like this:
rem
rem check to see whether this install script has already been run.
rem
if exist c:\eds\i-deas10\installed.txt goto EXITNOW
rem
--- more batch commands follow…
Then, down at the end of the installation script, include this:
rem write out a small file indicating the date & time of this installation
rem
echo "I-deas 10-M3 installation complete." >
c:\eds\i-deas10\id10_installed.txt
date /t >> c:\eds\i-deas10\id10_installed.txt
time /t >> c:\eds\i-deas10\id10_installed.txt
rem
:EXITNOW
echo.
echo I-Deas 10 is already set up on this machine.
echo.
The latter part writes out a small file when complete. When the script is
run again, it simply bails out right at the top. If I really want to
re-install on the machine, I just delete the “trigger” file.
Hope this helps.
--Jim Augeri
Honeywell International, Inc.
Aerospace - Albuquerque
Engineering Quality & Tools, MCAD
9201 San Mateo Blvd
Albuquerque, NM 87113
Highlighted
WF2 and IE7
Hello system managers,
Our IT department wants to roll out IE7.
I know from the past that there were some problems
with respect to run Pro/E in combination with IE7.
We are using at this moment WF2 build M160.
Do I have to expect any problems?
Upgrade to a certain build or version?
I have checked already the PTC knowledge base, but I can not find a
direct answer.
Any help is appreciated.
Thanks.
With kind regards, Met vriendelijke groeten,
Bert Busschers
Senior Mechanical Designer
Industrial Design & Mechanical Engineering Department
Lelyweg 10 - 7602 EA Almelo - The Netherlands (visit address)
P.O. Box 680 - 7600 AR Almelo - The Netherlands (postal address)
+31 546 535 209 (tel)
+31 546 535 299 (fax)
bert.busschers@bench.com
www.bench.com
MCAD Mananger Benchmark
