Better graphics
SOLVED
Highlighted
Newbie
Better graphics
Hi I am using Creo Parametric 2.0 Student's edition.
My rig is an i5 3.1 GHz with 8 gb RAM and an NVIDIA GTX 660 2 GB GDDR5 graphics card. When I try to create simple parts in creo parametric, their edges appear a tad distorted. How do I fix this to get smoother edges? I have tried using the NVIDIA control panel and changing the settings specifically for creo parametric, but the difference was negligible. Please help as soon as possible.
1 ACCEPTED SOLUTION
Highlighted
Re: Better graphics
try this:
shade_quality 10
enable_fsaa 16
edge_display_quality very_high
note:
your performance will be decreased when this settings are applied!
5 REPLIES 5
Highlighted
Re: Better graphics
go to file > options>model display> shade quality to maximum. check the other options too.
Highlighted
Re: Better graphics
try this:
shade_quality 10
enable_fsaa 16
note:
Re: Better graphics
smooth_lines yes
Highlighted
Re: Better graphics
Welcome to the forum, Sujit.
...This is possible in real-time:
Highlighted
Re: Better graphics
thank you so much
