Bold font in embedded browser
mzanini
3-Newcomer
I am using Creo Parametric Release 8.0 and Datecode8.0.2.0
Since a couple of week tthe font displayed in the embedded browser window appears in bold format and I can't set it to normal.
2 REPLIES 2
Mahesh_Sharma
22-Sapphire I
(To:mzanini)
Hi @mzanini
Does this apply to text outside of Windchill workspace as well? Does it happen in standalone browser?
Thanks.
MichaelW
(To:mzanini)
Hi @mzanini
you should have shared more information about your current setup.
Did you check those knowledge articles yet?
CS31975 Is it possible to adjust the embedded browser window's size and font in Workgroup Manager and Creo Parametric
CS46632 How to set font and style for menu, help, messages and embedded browser in Creo Parametric
Document Details - TPI 31527 (ptc.com)
  • 1. About the browser you are using: Each browser type has its own look and feel and (font) setup
Check config option: windows_browser_type (deprecated)
CS356984 Default browser in Creo Parametric changed to Chromium
  • 2. Just check, about Creo configuration (config.pro font setup): Have the default font values been overridden?
There are optional config options to actively control the entire font setup in one single line:
default_font: Model tree, Dialog boxes, Mapkey labels
menu_font: Mode-independent and Mode-specific menus
message_font: Message window
popuphelp_font: On-line help, Pop-up help
For example adjust or remove config here: Creo>File>Options>Configuration Editor>Add...
default_font arial, 14, plain, bold
menu_font helvetica, 16, italic, regular
