Browser stops working in older version of Creo when newer version is installed
Chris3
I have Creo 9 and 10 installed but Creo 7 is our production version. When Creo 9 or 10 gets installed the browser in Creo 7 stops working. Browser is set to Chrome.
Any idea how to prevent 9 or 10 from changing the browser in 7?
Install is a local install.
@MartinHanak wrote:
just little comment ...
1.] imagine I have clean computer without any Creo installation
2.] I install Creo 7.0 into c:\ptc\creo_parametric-7.0 directory
  • Creo 7.0 Platform Agent is located in c:\ptc\creo_parametric-7.0\Creo directory in two subdirectories - Agent and Platform
3.] I install Creo 8.0 into c:\ptc\creo_parametric-8.0 directory
  • Creo 8.0 Platform Agent installation updates the contents of c:\ptc\creo_parametric-7.0\Creo\Agent directory
  • Creo 8.0 Platform Agent is located in Creo 7.0 installation ... c:\ptc\creo_parametric-7.0\Creo\Agent directory
    and also in Creo 8.0 installation ... c:\ptc\creo_parametric-8.0\Creo\Platform directory
This means that the installations mentioned above are not independent !
Thank you for pointing that out. I should also have added that I also uninstall Creo Parametric after install. So my steps are:
  • On my laptop install Creo Parametric into version specific folder
    • c:/ptc/creo_parametric-10.0
  • rename the install directory to build specific eg
    • c:/ptc/creo_parametric-10.0.1.0
  • 7zip the renamed install directory
    • creates creo_parametric-10.0.1.0.7z
    • Use this for "installs" both local and network
  • rename the directory back to original name c:/ptc/creo_parametric-10.0 so the uninstaller will work
  • Uninstall Creo Parametric
    • Which then uninstalls the offending Creo Platform/Agent
    • This is actually much easier now with the uninstall all related items if you start with uninstalling Creo Parametric first
  • unzip the 7zipped earlier for a local "install"
    • This creates creo_parametric-10.0.1.0
    • rename to creo_parametric-10.0
Using this method allows you to easily have multiple versions/builds and switch easily by  simply renaming directories:
eg
  • c:/ptc
    • creo_parametric-10.0/
    • creo_parametric-10.0.0.0/
    • creo_parametric-9.0/
    • creo_parametric-9.0.4.0/
Firing up Creo Parametric 9.0 (custom bat file) will then launch what ever build is currently in c:/ptc/creo_parametric-9.0. This same custom script will set the CREO_AGENT_EXE_PATH and CREO_AGENT_LDP_LIST appropriately.
The PTC installer needs improvement for the Creo Platform/Agent installation.
13 REPLIES 13
BenLoosli
(To:Chris3)
Do you have this in your Creo 7 config.pro?
windows_browser_type chromium_browser
I have no problems switching between Creo 9.0.5.0 and 7.0.10.0.
Running them both just now to verify that I can switch between Creo sessions with no issues.
Chris3
(To:BenLoosli)
windows_browser_type chromium_browser is the default setting in Creo 7 and 8. In Creo 9 it is depreciated.
https://creosite.com/index.php/configuration/config-pro-option-search/compare-creo9-with-creo8-config-options/
https://www.ptc.com/en/support/article/CS356984
So no I don't have it set in my config.pro but it is set as the default by Creo.
llie
(To:Chris3)
We found out thru testing that you also need to set the computer default browser to Chrome. Having the two defaults (computer and Creo) set differently caused issues with stand alone Windchill, ModelCheck, and Creo embedded browser.
RandyJones
(To:Chris3)
I always install in a specified directory for each eg:
  • c:/ptc/creo_parametric-7.0
  • c:/ptc/creo_parametric-8.0
  • c:/ptc/creo_parametric-9.0
This way the creo agent/platform for each version get installed in it's own directory eg:
  • c:/ptc/creo_parametric-7.0/Creo
    • Agent
    • Platform
  • c:/ptc/creo_parametric-8.0/Creo
    • Agent
    • Platform
Then I set both CREO_AGENT_EXE_PATH and CREO_AGENT_LDP_LIST environment variables appropriately with a custom startup .bat file. See article CS255889.
Otherwise, despite what PTC claims about newer Platform/Agent working with older versions, it has never worked for me without doing these workarounds.
    • Agent
    • Platform
    • Agent
    • Platform
Martin Hanák
You're correct, that's one of the reasons that for our "installation" for users we have actually stopped installing Creo. We install once on a test computer, move the Creo folder from it's installation location to a similar location as shown above and add the lines for the .pcf files to find Agent and Platform. We then just zip up our installation location folder and our "installation" then just unzips those files into place. We were actually led to this when we had problems with Creo and WorkGroup Manager installations messing with each other's CreoAgent.
I use the same "installation procedure".
Martin Hanák
eg
  • c:/ptc
Chris3
(To:RandyJones)
Still working through this but we currently don't have the Creo agent set to a different path and I do believe that is my issue. CS255889 states:
Note: Do not set environment variable CREO_AGENT_EXE_PATH in case of Creo Platform services running from a local installation drive
I am not sure why it would matter but just to confirm you set the path to a local drive anyways? No issues?
MartinHanak
(To:Chris3)
below you can see two lines which I added at the end of parametric.psf in my Creo 9.0.2.0 local installation.
ENV=CREO_AGENT_EXE_PATH=E:\PTC\Creo9_020\Creo\Agent\creoagent.exe
ENV=CREO_AGENT_LDP_LIST=E:\PTC\Creo9_020\Creo\Platform\9\manifests
Martin Hanák
RandyJones
(To:Chris3)
No it does not matter the article is wrong in that case. Also see my reply to @MartinHanak above.
Chris3
(To:Chris3)
Apparently there is a bug in 10.0.1 that causes this issue. Do not install this version if you need to have multiple versions of Creo on your machine.
Article: https://www.ptc.com/en/support/article/cs182686
The solution si here
  • Go to Windows Control Panel Apps > select PTC Creo 10 Platform Services > Modify > Repair
https://www.ptc.com/en/support/article/CS398247
Software consultant.
