CGM created from a drawing have splits and curves
RGE
The cgm file created from drawing using File->Save a Copy..*.cgm is not equal to the drawing opened in ProE.
The cgm has splits in between lines and extra curves.
Please find the snapshot attached
Is there any settings which can resolve the issue.
VladimirN
24-Ruby II
(To:RGE)
Hello!
What version of Pro/E are you using?
RGE
(To:VladimirN)
Wildfire 3.0 M250
Setting intf2d_out_cgm_ver to 3 (default is 1) in config.pro is making some difference, but cgm created is having disjoint edges and there are curves
VladimirN
24-Ruby II
(To:RGE)
Could you provide a drawing sheet?
